Simplified circuit when boom is grounded
Source: InternetPublisher:方世玉223 Keywords: Ground potentiometer BSP Updated: 2021/12/07
The center tap of the precision potentiometer is connected to ground. When the sliding arm of the potentiometer is at the midpoint of the potentiometer, the sliding arm is grounded.
Assuming that the number of equalizer segments is 1, the circuit can be simplified as Figure 1-94. Since the operational amplifier can be regarded as an ideal amplifier
, its voltage gain is equal to the impedance ratio of the feedback branch.
In practical application circuits , the equalizer is often not one segment but one segment, such as 5 segments, 7 segments, and 10 segments. . When the sliding arms of the potentiometers
of these segments are all in the grounding position, it is equivalent to ri in Figure 1-94 becoming ri/yue, and
r2 becoming r2/
- Field effect tube amplifier circuit with beautiful sound
- Make a pocket amplifier with 8550 and 8050
- Telephone volume amplifier circuit
- Design and production of NE5532+TDA1521 amplifier
- DIY a stylish Bluetooth speaker
- Typical applications of optocouplers in audio amplifier circuits
- Audio power amplifier circuit composed of LM4835/4838
- LM4906 Audio Power Amplifier Circuit
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- Differential input audio amplifier circuit composed of LM4904
- Excellent performance household inverter power supply circuit
- Self-defense anti-riot circuit
- Electric massager circuit
- Pulse therapy circuit
- Varactor Diode Frequency Modulator
- base amplitude modulation circuit
- Broadband high frequency power amplifier circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Voltage series negative feedback amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
