AC load impedance after adding R3
Source: InternetPublisher:newrudeman Keywords: impedance feedback amplifier capacitor Updated: 2021/04/17
Capacitor cl shunts the output signal of the feedback amplifier . In the middle and bass areas, ct is similar to open circuit t and does not
play a shunt role. As the frequency increases, the shunting effect of cl increases,
even causing cl to short-circuit Rt. In this way, the input resistance of the tone circuit will
be reduced from Ri + Rz to R20. Usually R1 is several times or even 1-o times larger than R2. Therefore,
the load is very different from the load in the treble, so that The gain of the amplifier decreases as the frequency increases. Obviously, at treble,
the gain reduction and treble boosting cancel each other out.
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- Tutorial on making a MIDI arpeggio synthesizer
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- Make the most beautiful sound with the least money
- DIY 50W Gallstone Amplifier
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- A very simple amplifier
- Protection circuit and maintenance of household audio power amplifier
- Differential input audio amplifier circuit composed of LM4904
- LM4819 high gain audio amplifier circuit
- Sawtooth wave generator circuit (2)
- Capacitance measurement circuit c
- Feedback dielectric oscillator and equivalent circuit
- Electronic toy "Morning Bird" circuit
- HG40 series thyristor capacitor switch wiring
- Lightning protection wiring of phase-shifting capacitor on pole b
- Impedance compensation circuit
- Three-phase asynchronous motor is switched to single-phase power supply working circuit
- Capacitor displacement sensor application circuit
- High impedance 60HZ gain band stop filter circuit diagram
