Impedance compensation circuit
Source: InternetPublisher:傻阿乐 Keywords: Impedance compensation circuit BSP frequency divider Updated: 2020/08/26
If you feel that the periodic attenuator is not very convenient to use, we can divide the attenuation into smaller gears and then
use a switch to switch. For example, if the total attenuation is 6dB, it can be divided into three gears, each gear is 2dB. Calculate
the component parameters of each gear, connect the lines, and use switches to switch gears to meet the actual listening needs.
The voice coil of the speaker is an inductive component, and its impedance changes with the change of frequency. The higher the frequency,
the higher the impedance of the speaker. The correct design of the crossover requires that the impedance of the speaker is constant, so the change of the speaker impedance will Affects the frequency dividing characteristics of
the frequency divider .
When the impedance of a speaker connected to a crossover network changes, the filter turning frequency of the crossover network will
change greatly, causing confusion in the crossover characteristics, confusing phase characteristics, and making the frequency response of the speaker system uneven. ,
the overall performance of the system is affected, so it is necessary to perform impedance correction on the phenomenon that the speaker impedance changes with frequency. We generally compensate
for the increase in speaker impedance . The circuit is shown in the figure.
- TDA2009A power amplifier circuit
- Design and production of class AB headphone amplifier
- Design and production of NE5532+TDA1521 amplifier
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- A very simple amplifier
- Audio power amplifier circuit composed of LM4835/4838
- Dual power supply audio power amplifier circuit composed of LM3875
- Single power supply audio power amplifier circuit composed of LM3875
- Multimedia Hi-Fi amplifier circuit
- Horseshoe gallbladder preamplifier circuit
- Electronic anti-asthma circuit
- High-efficiency speaker circuit for rural stage
- Crop anti-frost circuit
- Rural vegetable greenhouse lighting circuit
- Capacitive feedback oscillator circuit
- Broadband high frequency power amplifier circuit
- Differential Amplifier Circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Guest arrival signal recognition circuit
- Motorcycle flash light circuit
