Working principle of bridge push-pull circuit
Source: InternetPublisher:newrudeman Keywords: push-pull circuit TI Updated: 2020/06/13
The IffL circuit is a bridge push-pull output power amplifier circuit. The output stage in the OTL and OCL circuits consists
of two output tubes working in turn. When one output tube VTi is doing "push" output, the other output tube VT2 is
resting ; when the other output tube VT2 When doing "pull" output, the output tube VTi is resting. This means that "push" and
"pull" do not work at the same time. They only work in turn in the positive and negative half cycles of the signal , and at the same time they cross to form a complete
output signal . It can be imagined that if such a circuit can be formed: when the vTi tube is "pushed" at one end of the horn, another
tube VT4 is "pull" at the other end of the horn; when the VT2 tube is "pull" at one end of the horn, the other tube is "pushed" at one end of the horn. There is a VT3 tube
"pushing" at the other end of the speaker. See Figure 1-40. In this way, the output efficiency of the output circuit composed of "push" and "pull" can be
greatly improved. The bridge push-pull output power amplifier circuit is composed like this.
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- Echo Dot speaker intelligent control system solution
- Homemade high quality preamplifier tone circuit
- Make a high-quality DAC board
- Homemade multi-sound effects sound system
- Electronic bird repeller for crops
- Protection circuit and maintenance of household audio power amplifier
- Horseshoe gallbladder preamplifier circuit
- LM4819 high gain audio amplifier circuit
- Active power amplifier circuit composed of TDA2003
- C-MOS inverter and its internal structure
- Low noise preamplifier (b)
- Complementary symmetrical push-pull circuit
- Diamond Differential BTL Power Amplifier Circuit-Power Amplifier
- 40W super power circuit
- Sound and light dual control delay energy-saving lamp (2)
- Shire YB-5T, YB-5TL, YB-5TI, YR-5M warm water dispenser circuit diagram
- Optocoupler TIL120/TIL121 connection equivalent circuit
- TIL153/TIL154/TIL155 type optocoupler circuit
- 5W amplifier circuit diagram using monolithic integrated series push-pull circuit TBA800
