Active power amplifier circuit composed of TDA2003
Source: InternetPublisher:smallembedded Keywords: Power amplifier circuit Updated: 2024/09/11
The circuit is shown in the figure. When making it, first install the voltage parallel negative feedback circuit. Test the collector voltage close to 1/2VCC in static state. Connect the signal generator to the input end. Output a sine wave voltage of 1kHzlomV~100mV. Connect the oscilloscope to the output end. Measure the largest undistorted waveform. This is mainly to strengthen students' understanding of negative feedback amplifier circuits. Then install the integrated amplifier, and pay attention to ensure that there is no short circuit between the pins. After power on, first test the static output of TDA2003 to be about 1/2Vcc. Then debug the whole machine. Choose OTL integrated power amplifier circuit. It is to prevent the speaker from being damaged during the debugging of the power amplifier circuit. TDA2003 has the characteristics of wide voltage range, large output power, strong overload capacity, and overvoltage protection function, which is very suitable for production.
- Making a Simple Tube FM Radio
- LM4766 Dual 40W+40W Power Amplifier
- 6C16+FU50 high-fidelity tube amplifier circuit with unique sound
- The production of 6P14 small tube amplifier
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- 6AS7 tube amplifier
- Stereo phono amplifier circuit with bass control composed of LM1877
- Multimedia Hi-Fi amplifier circuit
- Protection circuit and maintenance of household audio power amplifier
- Horseshoe gallbladder preamplifier circuit
- OTL low frequency power amplifier circuit
- Power amplifier circuit with comprehensive compensation
- Audio power amplifier circuit using TA8216A chip
- Audio power amplifier circuit using TDA2006 chip
- Integrated OCL power amplifier circuit composed of TDA2040
- Integrated OTL power amplifier circuit composed of TDA2040
- OTL power amplifier circuit
- A757 power amplifier circuit
- BTL power amplifier circuit
- LM378 two-channel audio power amplifier circuit with adjustment circuit
