Transistor Dual Differential Input Stage
Source: InternetPublisher:清宁时光 Keywords: Transistor BSP FET Updated: 2020/11/03
A transistor double differential circuit is used as the input stage, as shown in Figure 1-37. Analysis of this circuit shows that since a
pair of differential circuits with different polarities are connected, their base currents are opposite. Therefore, there is almost no current flowing through the bias resistors on both sides,
so the resistors on both sides can be of any value. The difficulty is that the parameters of the left and right, upper and lower tubes must be strictly consistent.
Use field effect tube differential (or double differential) circuit for A-level output. For IX: power amplifier, using field effect transistor (generally junction type
) differential circuit as the input stage is the most convenient, reliable and stable circuit form. The general OCL circuit cancels CF and becomes a DC
power amplifier, and its circuit structure can remain unchanged. . Because the field effect transistor is a voltage-controlled component with a very high input resistance and basically
draws no current, the bias resistors of the two differential tubes can be set to any value without changing their static bias voltage and drain current .
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- How to adjust the bass and treble of CXA1005
- DIY 50W Gallstone Amplifier
- Sugon New Tube 2A3C Single-ended Tube Amplifier
- Make a pocket amplifier with 8550 and 8050
- The production of 6P14 small tube amplifier
- Make cheap speakers using waste circuit boards (TDA1013)
- 8W audio power amplifier circuit composed of LM2002/LM2002A
- Audio amplifier circuit of the Expo flowerpot speaker
- Application of BTL power amplifier circuit composed of LM3886
- Voice controlled flash LED light circuit diagram
- Pulse therapy circuit
- Physiotherapy ventilator circuit
- Diode Balanced Mixer Circuit
- base amplitude modulation circuit
- Inductive feedback oscillator circuit
- Capacitive feedback oscillator circuit
- OTL low frequency power amplifier circuit
- Color display circuit
- Sine wave signal generator circuit
