Inductive feedback oscillator circuit
Source: InternetPublisher:笑流年 Keywords: Oscillator circuit BSP transistor Updated: 2021/04/08
The inductive feedback oscillator circuit is as shown in the figure, and the transistor is 3DG3.
The reference values of component parameters are as follows:
1) The transistor is 3DG6.
2) Resistor: Rhl =91kfl, RbZ=llkfl, Re =IkSl.
3) Capacitor: C=C=C=0.OlyF.
4) The values of C, LJ and L2 are determined by the oscillation frequency of the oscillator.
As can be seen from the AC equivalent circuit, the capacitor C and the inductor L. , Lz form a
selective loop, and the emitter of the transistor is grounded. Output voltage Uo - UI], feedback voltage
Uf -UL2, the phase difference between feedback voltage Uf and output voltage U<. is 180. , satisfying the positive
feedback condition. The three electrodes of
the transistor are connected to the three nodes of the inductor respectively. This circuit is called a three-point oscillator circuit ; and because the feedback voltage is taken from
the voltage at both ends of the inductor, this circuit is also called an inductive feedback three-point oscillator.
- Share the features of Wi-Fi 6 that you don’t know
- Design and production of satellite receiver crash recovery circuit
- AM Transmitter
- MAX2820/MAX2821 I/Q 2.5-2.4 GHz Transceivers
- MICRFl04 ASK 470~300 MHz Transmitter
- U3742BM ASK/FSK 433.92/315 MHz Receiver
- MCl3175/MCl3176 FM/AM 928~902 MHz/470~260 MHz Transmitter
- Eight-way remote control transmitter circuit using CS901
- rfRXD0920 ASK/FSK/FM 930~800 MHz Receiver
- DKIOOOT OOK 315 MHz Transmitter Module
- Physiotherapy ventilator circuit
- Fish pond oxygenation reminder circuit
- Particle clogging alarm circuit of wheat seeder
- Farmland irrigation automatic control circuit b
- Diode balanced amplitude modulation circuit
- Wien bridge oscillator circuit
- Series crystal oscillator
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Double gate field effect transistor high frequency amplifier circuit
- Home appliance repair signal generator circuit
