Application circuit of HA1397
Source: InternetPublisher:红水杯 Keywords: Application circuit BSP output power Updated: 2020/12/27
In the application circuit , pins 1, 2, and 4 are empty pins and are not connected to any components. Pins 5 and 12 are connected to unregulated positive and negative
power supplies respectively. 6. Add a regulated power supply between pins 12 and 12. At the rated output power , the voltage gain G v=R4/R3=38dBo
HA1397 has a maximum output power of up to 30W when the ultimate operating voltage is ±30V .
- The easy production of several top-quality tube preamplifiers
- Make a high-quality DAC board
- Sugon New Tube 2A3C Single-ended Tube Amplifier
- Telephone volume amplifier circuit
- Using Shuguang 350C tube to make tube amplifier
- Minimum output noise/reduced output power circuit using LM4910
- LM4820-6 audio power amplifier circuit
- Tube single-ended class A 300B power amplifier circuit
- Differential input audio amplifier circuit composed of LM4904
- Horseshoe gallbladder preamplifier circuit
- strain sensor
- Bone hyperplasia treatment circuit
- Agricultural temperature control circuit
- Diode Balanced Mixer Circuit
- ring amplitude modulation circuit
- Crabo oscillator circuit
- Differential Amplifier Circuit
- High and low frequency signal generator circuit
- Three primary color display circuit
- Sine wave signal generator circuit
