Power supply and protection circuit
Source: InternetPublisher:通通 Keywords: protection circuit power supply power supply low voltage Updated: 2020/10/06
In terms of power supply, a double-bridge power supply is used, that is, the positive and negative power supplies are separately rectified and filtered, and the suspended grounding method is used for power supply . The first half of the circuit
uses high-voltage power supply, and the second half uses low-voltage power supply . Separating the front and rear stages is beneficial to reducing mutual influence, reducing
hum, and improving the signal-to-noise ratio. Its power supply and protection circuit are shown in Figure 244.
- How to adjust the bass and treble of CXA1005
- DIY 50W Gallstone Amplifier
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- Design and production of NE5532+TDA1521 amplifier
- Stereo phono amplifier circuit with bass control composed of LM1877
- LM4906 Audio Power Amplifier Circuit
- 8W audio power amplifier circuit composed of LM2002/LM2002A
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- Differential input audio amplifier circuit composed of LM4904
- American Grado RA1 headphone amplifier
- Ultra-low dropout linear voltage regulator circuit
- Micropower low dropout adjustable integrated voltage regulator application circuit 05
- Micropower low dropout adjustable integrated voltage regulator application circuit 02
- Low voltage dropout and low power consumption three-terminal voltage regulator circuit
- DC low voltage regulated power supply circuit diagram
- low voltage flasher
- Voltage sensitive resistor for lightning protection circuit on low voltage side of distribution transformer
- Low dropout voltage stabilization circuit diagram
- Low voltage automatic conversion circuit diagram
- Simple voltage type low voltage electric shock safety device circuit diagram
