Stereo phono amplifier circuit with bass control composed of LM1877
Source: InternetPublisher:桂花蒸 Keywords: Stereo amplifier circuit Updated: 2024/09/18
As shown in the figure, this is a stereo phono amplifier circuit with bass control composed of LM1877. The stereo metal ceramic pickup picks up the stereo left and right channel audio signals on the turntable, which are input through two 1MΩ potentiometers and coupled by two 0.1μF capacitors to the input terminals 6 and 9 of LM1877 respectively. After amplification, they are output from pins 2 and 13 respectively and sent to the left and right channel speakers respectively. Among them, the two 1MΩ potentiometers are volume potentiometers, and the two potentiometers are linked to adjust the volume. The two 1MΩ resistors connected to pin 1 are used to set the DC bias operating point of the amplifier, and at the same time, they form an input high-pass filter with the 0.1μF coupling capacitor. The 100kΩ potentiometer connected to the feedback loop between pins 2 and 7 of the amplifier (similarly, the 100kΩ potentiometer connected to the feedback loop between pins 13 and 8 of the amplifier) is a bass control potentiometer. The 2.7Ω resistors and 0.1μF capacitors connected in parallel with the left and right channel speakers are used to filter out high-frequency noise.
- TDA2009A power amplifier circuit
- Field effect tube amplifier circuit with beautiful sound
- Make a high-quality DAC board
- Telephone volume amplifier circuit
- 6AS7 tube amplifier
- Electronic bird repeller for crops
- Audio power amplifier circuit composed of LM4835/4838
- Bridge output audio power amplifier circuit composed of LM1876
- LM4915 is used for dual-channel amplifier circuit
- Differential input audio amplifier circuit composed of LM4904
- Seven basic analog circuits
- Field effect transistor sound control amplifier circuit
- Highly stable thermocouple temperature measurement amplifier circuit composed of OP07
- Broadband amplifier circuit
- High output voltage amplifier circuit
- Multistage DC coupled amplifier circuitb
- Two-stage DC-coupled amplifier circuit
- Positive-phase AC amplifier circuit that can increase input impedance 10 times
- Common drain amplifier circuit
- In-phase stereo amplifier circuit
