Debugging distortion
Source: InternetPublisher:奥特man123 Keywords: BSP Updated: 2021/11/27
If there is no distortion meter, the following method can be used for debugging : Temporarily connect a test circuit as shown in Figure 2-9, input a 20kH,
0.7V sine wave signal, and record the indicated value of table PA. If the value is larger, adjust the RP keeps the instructions moderate.
Then move the switch SA to the other side, adjust Wei) l and RP4 to minimize the indicated value, and adjust repeatedly until satisfied.
The component model can be selected according to the requirements in the figure, and its technical parameters should be selected according to the power supply voltage and output power requirements by referring to the previous
circuit selection method. Although this circuit does not have high requirements for component pairing, tubes of the same grade should be used as much as possible
. Resistors ‰~R52 can be 2 to 3W wirewound resistors, and try to use non-inductive resistors. The rest can be metal film
resistors orRPi~. RP4 uses solid core carbon film potentiometer.
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- Make a high-quality DAC board
- Make the most beautiful sound with the least money
- Sugon New Tube 2A3C Single-ended Tube Amplifier
- The fun of making ISD1820 voice recording box
- Using Shuguang 350C tube to make tube amplifier
- Electronic bird repeller for crops
- Auxiliary audio power amplifier circuit using LM4730/LM4731
- Stereo phono amplifier circuit with bass control composed of LM1877
- High gain audio amplifier circuit composed of LM4818
- Smoking Cessation Circuit
- soil content measurement circuit
- Egg warming circuit
- Straw returning to field crusher circuit
- Soil water shortage prompt circuit
- Domestic KD8041 integrated phase locked loop
- Proportional frequency discriminator circuit
- Second-order active band-stop filter circuit
- Three primary color display circuit
- Motorcycle flash light circuit
