Integral circuit with approximately ideal characteristics
Source: InternetPublisher:方世玉223 Keywords: BSP frequency characteristics Updated: 2020/01/12
If there is an error in the term with ", -" in the formula, you can increase the leakage voltage Vos or increase the resistor
R2
marked with ★ to compensate for J. The error caused by the cover can be reduced, or
the error can be reduced by reducing the resistance of roar and increasing the capacity of c.
As shown in Figure ^, when an AC signal is input,. It can be seen from the frequency axis that
. It is extremely critical to set the position in the circle. The frequency is low and fc, and the gain
rises at 10 6dB/oct c20dH/dec). When = 0, the gain should be infinite (subject to
the open-loop gain limit) o
:j To obtain For incomplete integration characteristics, a feedback resistor Ri can be added (
connected with C). Assume 4=-Hall, / and l,, = 1/2 FR,. cl, so that the
open-loop frequency characteristics of the OP amplifier with internal position compensation are the same as those of the integral circuit.
increase the value marked with ★ Resistor R2 to compensate J. The error caused by the cover can be reduced, or
:j To obtain For incomplete integration characteristics, a feedback resistor Ri can be added (connected with C
the open-loop frequency characteristics of the OP amplifier with internal offset compensation are the same as those of the integrating circuit ,
- DIY Metal Detector
- Simple and practical motor short circuit tester
- Isolated 4-20mA instrument loop (RTD) circuit composed of RCV420
- NE555 makes a simple and practical acupoint detector
- Circuit Fault Tracker
- Leakage Tester
- How to Use a Radio as a Metal Detector
- Geiger counter circuit diagram
- 3W portable megaphone circuit
- Typical two-stage low-pass filter circuit
- Self-defense anti-riot circuit
- Chicken supplementary light to increase egg production rate circuit
- Agricultural spraying and insecticide control circuit
- Double detuned loop frequency discriminator circuit
- Amplitude modulation circuit composed of MC1496
- ring amplitude modulation circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Voltage-controlled voltage source second-order active low-pass filter circuit
- High and low frequency signal generator circuit
- Three primary color display circuit
