Double detuned loop frequency discriminator circuit
Source: InternetPublisher:containsmachine Keywords: BSP Updated: 2021/09/04
The actual circuit of the double detuned loop frequency discriminator used in the microwave communication machine is as shown in the figure. The resonant frequencies of the two loops are set to
35MHz and 40MHz respectively.
The transistor is 3DG12 and the diode is 2AP9×2.
In the figure, the FM signal carrier frequency is 37. 5MHz, which is amplified by two common-base amplifiers and then added to two resonant loops respectively, and the connection point of the two
loops is grounded together with the detection capacitor. Since the ground point changes, the output voltage ‰ is taken out from the middle of the detector resistor, so
the directions of the detector diodes VD1 and VD2 are opposite.
- Analysis of the reasons why bow-tie antennas are preferred over microstrip antennas for 5G antennas
- Production of a FM wireless microphone
- FM transmitter in a matchbox
- AM Transmitter
- XEl209 70~30 kHz Ultra-Low Power CMOS Transceiver
- Radio coding transmission circuit composed of MICRF102 and PT2262
- nRF903 GMSK/GFSK 950~430 MHz transceiver
- RXM-433/418/315-LC-P AM Receiver Module
- TQ5638 KPCS CDMA/GPS 2090 ~ 1620 MHz Dual Mode Receiver
- AT86RF211 FSK 950~400 MHz transceiver
- strain sensor
- Pulse therapy circuit
- Fish farming thermostatic control circuit
- Farmland irrigation automatic control circuit b
- Simple AGC circuit in transistor radio
- collector amplitude modulation circuit
- Wien bridge oscillator circuit
- Double gate field effect transistor high frequency amplifier circuit
- Second-order active band-stop filter circuit
- Digital stopwatch display circuit
