Photo-controlled switching circuit composed of silicon photovoltaic cells
Source: InternetPublisher:偷熊计划 Keywords: Switch circuit battery pack silicon photovoltaic cell light control switch Updated: 2021/02/07
In the circuit shown in the figure, when there is no light, VT is cut off (or there is a small collector current, but not enough to make the relay close); when the silicon photovoltaic cell is illuminated by light, a forward voltage is generated to turn on VT, and the relay action.
- Analysis of the working principle of switching regulator
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- A very convenient small power supply circuit to share
- In-depth analysis of DC-AC converter inverter
- Practical and convenient fax machine power supply control circuit
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Basic connection circuit of signal and power supply composed of ISOll3
- Constant current charger using light emitting diode as voltage regulator
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- The production of adjustable voltage-stabilized power supply composed of LM317
- Loom power saving automatic switch circuit
- Ultrasonic remote control lighting switch circuit a
- FM modulator strong-weak signal switching circuit a
- One of the automatic periodic switching circuits
- JK7 proximity switch circuit
- Contactless proximity switch circuit 2
- Two-phase three-phase zero-voltage switching circuit using KC08 integrated circuit
- Light control switch circuit 3 controlled by flashlight
- Simple and practical light control switch circuit
- Integrated light control switch circuit
