Light control switch circuit 3 controlled by flashlight
Source: InternetPublisher:黄土马家 Keywords: Switch circuit flashlight light control switch Updated: 2021/09/25
It uses photosensitive resistors RG1 and RG2 as detection components, and transistors as control and switching
functions.
When the power is turned on, the relay KA is closed and the load is turned on. When the flashlight shines on the photoresistor RGz, KA is released
and the load is cut off. To start up (connect the load), you can use a to shine on the photoresistor RG.
Resistors Rl and R2 play the role of stabilizing the operating points of transistors VTi and VTz respectively. By adjusting Ri and R2,
the sensitivity of RG1 and RGz can be adjusted respectively.
- Making a photometer with light measuring function
- Low cost LED automatic emergency light circuit
- Design and production of rain control and light control timing controller based on P87LPC764
- Musical doorbell without buttons
- Low illumination amplifier circuit
- Lighting lamp voltage stabilizing circuit (2)
- Resistor value selection circuit
- Lighting sound-activated switch circuit using thyristors Part 3
- Frost alarm circuit
- Fluorescent lamp electronic ballast circuit 11
- Infrared proximity switch circuit diagram
- Mos tube switch circuit diagram
- FM modulator strong-weak signal switching circuit b
- Touch bistable switch circuit
- Photoelectric control switching circuit composed of photoresistor lamp elements
- Lighting sound and light control switch circuit 4
- One of the light control switch circuits controlled by flashlight
- Light control switch circuit 3 controlled by flashlight
- Simple light control switch circuit
