12v/6A charging circuit with excellent charging curve and automatic circuit breaking
Source: InternetPublisher:三月小雨 Keywords: Break circuit charging circuit BSP Updated: 2020/04/17
![12v/6A<strong>Charging Circuit</strong> with excellent charging curve and automatic<strong>Circuit Break</strong>](http://www.eeworld.com.cn/circuit/upload/efb015cd38d18d0e026379d2bacd0347/af785aa5796c16c0af3739fa21bde0dc.gif)
It is related to the size of the load current , as well as the symmetrical resistors R5 and R6, the parallel potentiometer , and the output power supply of the operational amplifier OP.
Thermistor RL plays the role of overheating and overload protection, and is installed together with the radiator of power tubes T2 and T3. The base current and load current are limited , thereby reducing heat generation to an allowable level.
- How about the boost converter TPS61299?
- Benefits of Wide Bandgap Technology for Power Converters
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Fabrication of multi-cell lithium battery charging circuit
- Recommended circuits for different power on times of LM4911
- Visible laser digital control modulation driver
- The constant current source composed of two transistors can drive high power
- Parallel DC regulated power supply circuit diagram
- Current/voltage conversion circuit using current converter
- CNC regulated power supply production
- Motor forward and reverse control wiring diagram (2)
- strain sensor
- Egg warming circuit
- Peanut and melon seeds roasting machine circuit
- Rice mill circuit
- ring amplitude modulation circuit
- Inductive feedback oscillator circuit
- Voltage series negative feedback amplifier circuit
- High and low frequency signal generator circuit
- Color display circuit
