AVK200 home theater amplifier and maintenance 04
Source: InternetPublisher:柯南道尔 Keywords: Home theater amplifier BSP Updated: 2021/04/27
(4) The Dolby decoding circuit
AV K20 0 decoding chip uses NJW1102 from Japan's JRC Company. The decoding circuit is shown in Figure 10-25.
The data sent by 1N2 is input to the @~@ pins of 2N4 through lxl, so that 2N4 makes corresponding state changes;
three sound field modes: 2CH (i.e. traditional stereo mode); Than 3 STEREO (in this mode, the surround channels do not work
); Dolby Pro Logic state.
Three center modes: normal mode (NORM), wideband mode (WIDE), and phantom mode (PHANTOM). In phantom
mode, the + center channel does not work, and the center signal is assigned to the left and right channels.
Four-speed surround delay: 15ms, 20ms, 25ms, 30ms o
Noise sequence test <TEST)々
- Using TDA2822 to do direct coupler output experiment
- Make a high-quality DAC board
- Make a pocket amplifier with 8550 and 8050
- DIY a stylish Bluetooth speaker
- Make cheap speakers using waste circuit boards (TDA1013)
- Stereo tube power amplifier
- Minimum output noise/reduced output power circuit using LM4910
- 2W×2 power amplifier circuit using LM1877
- Multimedia Hi-Fi amplifier circuit
- Protection circuit and maintenance of household audio power amplifier
- strain sensor
- Agricultural temperature control circuit
- soil content measurement circuit
- Poultry warming temperature control circuit
- Farmland irrigation automatic control circuit a
- ring amplitude modulation circuit
- Differential Amplifier Circuit
- common emitter amplifier circuit
- Fault signal trip circuit
- Sawtooth wave generator circuit (2)
