60 watt laptop battery charger circuit
Source: InternetPublisher:newlandmark Keywords: battery charger charger circuit laptop computer AC power supply Updated: 2020/05/23
This circuit is designed for laptop battery charger , 20V output voltage. This circuit uses Power Integrations' TOP 246?. TOP 246 Eliminates half of the discrete components compared to the UC3842. This IC is due to its promise of integration power, greater reliability, smaller form factor, reduced design time and cost savings.
Battery charger features:
Input voltage AC: 85...265V (universal input) ; Overall efficiency
at 85V AC power supply
is not less than 79
%;, Overall efficiency at 265V AC power supply
is not
less than 84%;, Output
DC voltage: 20V, maximum load Current: 3A.
- Basic connection circuit of signal and power supply composed of ISOll3
- Use pulse width modulation to get a precise output voltage
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LNK304 non-isolated LED light string driver circuit
- Power supply circuit that can reduce LM317 ripple
- Adjustable voltage power socket
- Converting a lithium battery charging board into a constant voltage and current charger
- Car Audio Power Supply
- Practical constant current charger-----Constant current charger
- Cadmium nickel battery charger circuit three
- AC power supply voltage out-of-limit indication circuit
- Fuse blown indication circuit 2
- Dedicated servo stabilized power supply for power amplifier
- Backup power automatic charger circuit
- SH-803 Holiday Lights ASIC
- New fast charging I simple charger circuit
- Automatic charger circuit
- Soft Start AC Power Circuit
