2x80WHI-FI power amplifier 01
Source: InternetPublisher:JFET Keywords: Power amplifier HI-FI BSP tube Updated: 2021/06/08
As we all know, the current use of VMOS FET power tubes in foreign countries can produce high-power amplifiers that are close to the reproduction effect of electronic tubes
, and the heat generation and power consumption are better than those of electronic tubes. 9. The differential amplifier composed of VMOS tubes at the front input end also reduces the input
impedance. It is very high, its driving current is only 0. lvA, and its on-resistance is small, its operating frequency is high, its dynamic range is large, and it is not easy to saturate. 6
Technical indicators:
(】) Rated power: 80w×2 (phoenix=8n);
(2 ) Frequency response: 4 Hz~100kHz (±0.5dB)}
(3) Harmonic distortion: 0.018 (3:2Hz~20kHz);
(4) Signal-to-noise ratio: >89dB (input terminal connected to 600fl resistor);
(5 )Input sensitivity: 380m V.
The output power is completely determined by the power of the final field effect transistor. The purpose is: IRF9130 and IRF150 are complementary; the power supply voltage
is ±42V, provided by a dedicated switching power supply for the power amplifier.
- Convenient and fast power line break detection circuit
- Homemade simple magnetic material tester
- Homemade Metal Detector
- Leakage Tester
- LM3914 makes car battery detector
- Production of acoustic and optical digital level detector
- Directly coupled push-pull power amplifier circuit
- Typical two-stage low-pass filter circuit
- High-speed gain programmable amplifier circuit
- Differential amplifier circuit
- Motor forward and reverse control wiring diagram (2)
- Pulse therapy circuit
- Agricultural small tractor lighting circuit
- Biogas concentration detection line
- Frequency modulator composed of NE566
- ring amplitude modulation circuit
- Wireless microphone circuit
- Color display circuit
- Fault signal trip circuit
- Sawtooth wave generator circuit (1)
