Six LED stereo VU display circuit built with IC LM3915
Source: InternetPublisher:JFET Keywords: led display circuit LM3915 Updated: 2024/03/04
The figure below is a scheme diagram of a six-LED three-dimensional VU display circuit built using the dot/bar display driver IC LM3915. This VU display should be connected before the amplifier module circuit. You can connect this circuit to a preamp output, tone control input/output, or equalizer input/output. This circuit is powered by 12V DC power supply.
About LM3915:
The LM3915 is a monolithic integrated circuit that senses analog voltage levels and drives ten LEDs, LCDs, or vacuum fluorescent displays, providing a logarithmic 3 dB/step analog display. One pin changes the display from a bar graph to a moving dot display. LED current drive is adjustable and programmable, eliminating the need for current limiting resistors.
The LM3915's 3 dB/step display is suitable for signals with a wide dynamic range, such as audio level, power, light intensity or vibration. Audio applications include average or peak level indicators, power meters, and RF signal strength meters. Replacing traditional gauges with LED bar graphs allows for faster response, a more robust display and high visibility, while maintaining the ease of interpretation of an analog display.
The LM3915 is very easy to apply. In addition to 10 LEDs, a 1.2V full-scale meter requires only one resistor. An additional resistor sets the full-scale range from 1.2V to 12V, independent of the supply voltage. The brightness of the LED is easily controlled with a single potentiometer.
- One-digit display
- TEC laser diode driver circuit
- LED Flasher circuit using 2 transistors for LED switching
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- Electronic massage and acupuncture device circuit
- Low illumination amplifier circuit
- "OR" logic element configuration circuit
- Gas flameout alarm circuit
- Electronic music dimming desk lamp circuit
- 6-digit cathode fluorescent triode display circuit
- Analysis of various forms of packaging structures of LED light-emitting diodes
- MAX684 charge pump driving white LED circuit diagram
- Three-phase phase loss alarm light circuit
- NE555 typical application circuit diagram (2)
- 5-point LED driver circuit diagram of HA7666P/TA7667P
- Wall wire detection circuit
- Constant temperature measurement circuit
- Electric blanket internal disconnection measurement circuit
- LED billboard decorative light circuit
- Eight-way light-touch electronic interlock switch circuit
