Practical current feedback integrated amplifier 02
Source: InternetPublisher:失踪的猫 Keywords: Power amplifier current feedback BSP Updated: 2021/08/08
The tone circuit uses LM 1036 from NS Company in the United States .
The front-end uses high-quality audio tubes to form a large-loop feedback circuit, and the resolution is significantly improved compared to the op-amp front-end. The primary is the emitter, and
the resistor-capacitor network of the emitter can effectively stabilize the DC operating point. It can also communicate smoothly. The pre-reverse amplification gain is 7dBO.
The power amplifier circuit uses the new DMOS product TDA7294 of the famous European SGS company. This integrated block has extremely low noise and distortion
, and comes with mute, standby, overheating protection, and short-circuit protection. The working voltage of the circuit port is plus or minus 10V to plus or minus 40v. According to Figure 6-15, it
is connected into a current feedback circuit t and uses an op amp NE5 ,532 form a DC servo circuit to stabilize the zero position of the midpoint voltage of the output . The tone is more mellow and has a "bold" taste. The tone and pre-power supply are
stabilized
by a highly stable mirror constant current source and an extremely low-noise light-emitting diode.
voltage, and then the Darlington sampling composed of high-quality audio tubes outputs a stable and strong current. The circuit is shown in Figure 6-16. Practice has proved
that using this power supply to power the LM 1036 and the front is better than the three-terminal voltage stabilization effect.
- Bat sound detection circuit
- Fire detector made with photodiode
- Multi-speed current test circuit of transistor HFE
- How to Simplify Analog Front-End Design for Heart Rate Monitors
- Homemade LED digital display photovoltaic meter
- Transistor reverse breakdown voltage tester-----Transistor tester
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- AC equivalent amplifier circuit
- Geiger counter circuit diagram
- 3W portable megaphone circuit
- Set timing circuit when power is on
- Analysis of rectifier circuit types and principles
- High-efficiency speaker circuit for rural stage
- Particle clogging alarm circuit of wheat seeder
- Agricultural spraying and insecticide control circuit
- Soil water shortage prompt circuit
- Diode balanced amplitude modulation circuit
- Series crystal oscillator
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Sawtooth wave generator circuit (1)
