500W RMS power amplifier circuit design based on MOSFET
Source: InternetPublisher:失踪的猫 Keywords: MOSFET power amplifier amplifier circuit Updated: 2024/01/05
This is a 500WRMS power amplifier circuit design based on MOSFET. This circuit is very popular among EE audio enthusiasts as "LEGENDstageMasterMK2". This is a very good and powerful amplifier. It uses 12x power MOSFETIRFP240.
In order to achieve greater power, their often interested younger friends developed a more powerful version, capable of producing a full, true 500WRMS into 8 ohms. Such a big power had to resort to somewhat completely different solutions for better reliability or to increase the complexity of the tiles, so it is impossible for this version to use the same tiles as the previous two lower models ( Legend and Legend Stage Master).
Specification:
Output power——500WRMS/8ohms
Frequency range 15Hz-130kHz (-1dB) at30WRMS
THD=《0.18%(at1kHzand500W)
THD=《0.01%(at1kHzand400Wandbelowthispower)
BIAS per output pair is approximately 25mA
500WRMS power amplifier PCB design and layout
It's PCB design and component placement, you should mount the MOSFET on a heat sink to prevent overheating and maintain the performance of the power amplifier.
This circuit was designed by Dr. Borivoje Jagodic, the original page is for reference.
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- The easy production of several top-quality tube preamplifiers
- Simple and practical small amplifier
- Make a high-quality DAC board
- 18-inch large speaker
- A very simple amplifier
- Bridge output audio power amplifier circuit composed of LM1876
- Auxiliary audio power amplifier circuit using LM4732
- Stereo amplifier circuit with Av=200 (gain) composed of LM1877
- Active power amplifier circuit composed of TDA2003
- Car window control circuit
- TDA7245 power amplifier circuit diagram
- TDA2009 power amplifier circuit diagram
- TDA2004 power amplifier circuit diagram
- TDA1519 power amplifier circuit diagram
- TDA1015 power amplifier circuit diagram
- TA7271P power amplifier circuit diagram
- TA7270P power amplifier circuit diagram
- TA7250P power amplifier circuit diagram
- STK460 power amplifier circuit diagram
