Practical current feedback integrated amplifier 01
Source: InternetPublisher:吃掉星星 Keywords: Power amplifier current feedback BSP Updated: 2021/07/25
The tone circuit uses LM 1036 from NS Company in the United States .
The front-end uses high-quality audio tubes to form a large-loop feedback circuit, and the resolution is significantly improved compared to the op-amp front-end. The primary is the emitter, and
the resistor-capacitor network of the emitter can effectively stabilize the DC operating point. It can also communicate smoothly. The pre-reverse amplification gain is 7dBO.
The power amplifier circuit uses the new DMOS product TDA7294 of the famous European SGS company. This integrated block has extremely low noise and distortion
, and comes with mute, standby, overheating protection, and short-circuit protection. The working voltage of the circuit port is plus or minus 10V to plus or minus 40v. According to Figure 6-15, it
is connected into a current feedback circuit t and uses an op amp NE5 ,532 form a DC servo circuit to stabilize the zero position of the midpoint voltage of the output . The tone is more mellow and has a "bold" taste. The tone and pre-power supply are
stabilized
by a highly stable mirror constant current source and an extremely low-noise light-emitting diode.
voltage, and then the Darlington sampling composed of high-quality audio tubes outputs a stable and strong current. The circuit is shown in Figure 6-16. Practice has proved
that using this power supply to power the LM 1036 and the front is better than the three-terminal voltage stabilization effect.
- Simple and practical EPROM detection circuit
- Simple and practical motor short circuit tester
- Digital electronic thermometer using semiconductor diode as temperature sensor
- Level measurement circuit composed of AD737
- NE555 makes a simple and practical acupoint detector
- Simple infrared detector
- LM3914 makes car battery detector
- Typical two-stage low-pass filter circuit
- voltage amplifier circuit
- Sample and hold circuit diagram
- Set timing circuit when power is on
- Analysis of rectifier circuit types and principles
- High-efficiency speaker circuit for rural stage
- Particle clogging alarm circuit of wheat seeder
- Agricultural spraying and insecticide control circuit
- Soil water shortage prompt circuit
- Diode balanced amplitude modulation circuit
- Series crystal oscillator
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Sawtooth wave generator circuit (1)
