8-bit bipolar DA converter that generates sine waves
Source: InternetPublisher:蓝猫淘气 Keywords: sine wave converter BSP Updated: 2021/05/18
ICih8-bit data memory circuit. Sending 8-bit data to
DAC08 during the Monday period can reduce errors caused by poor timing. Because the soap output terminal is thin. The
stabilization time is very short, 85ns, and the voltage conversion circuit has high switching speed requirements
, so the selected voltage converter uses a high-speed OP circuit. : The electric current is used to determine the base
current in early heat, usually 2mA at full scale, but this circuit takes IerAJ4L, _, and
when the digital data is ooll, +lo=OmAi is FFⅡ -+Io=
0. 61mA (1x 255/stimA), - Rujing input fish dropout of electricity.
The zero-level output is basically the center value of digital data. . When the number is 8F.
, +,. =0.smA,-J. =0. Wow 061mA,. I.with_j. There is
a deviation of 3-9u.A, which is converted into voltage of 19.53mV. Use V to adjust the confidence
to make the circuit confident (the tank range deviates from 1'/2LSB);
- Simple and convenient remote control receiver dual purpose detector
- Balcony intelligent invisible anti-theft net
- New function added to MF-47D multimeter - infrared remote control detection
- 4040 Mobile Phone Electromagnetic Radiation Demonstration Experiment Circuit
- DIY Multimeter High Frequency Signal Probe
- Isolated 4-20mA instrument loop (RTD) circuit composed of RCV420
- Using NE555 to make diode and triode detector
- How to use STM32 to design an alcohol tester
- AC equivalent amplifier circuit
- Phase sequence indicator circuit diagram
- Self-defense anti-riot circuit
- Electric massager circuit
- Agricultural temperature control circuit
- soil content measurement circuit
- Fish farming thermostatic control circuit
- Greenhouse temperature control circuit
- Soil water shortage prompt circuit
- Diode balanced amplitude modulation circuit
- Series crystal oscillator
- Capacitive feedback oscillator circuit
