Fish farming thermostatic control circuit
Source: InternetPublisher:aytwartoofyoroo Keywords: Thermostatic control circuit BSP LED Updated: 2021/04/28
(1) Circuit composition The thermostat controller circuit for fish breeding consists of a power supply circuit and a temperature detection control circuit, as shown.
The power circuit is composed of power transformer T, rectifier diodes
VD2, VD3, filter capacitor island, current limiting resistor and power
indicator light-emitting diode LED 1.
The temperature detection control circuit consists of thermistor RT, resistor
, Rz, and capacitor C. , potentiometer RP, time base integrated circuit
1C, heating work indication light-emitting diode LED2, relay K
and diode VD1.
(2) Circuit principle After the AC 220V voltage is stepped down by T,
rectified by VD2 and VD3 and filtered by G, a +9V voltage
(ux.) is generated and supplied to 1C, and at the same time LED1 is lit through R3.
When the water temperature is lower than the set temperature of RP, the resistance of +RT
becomes larger. Make the voltage of pin ② of LC lower than V(1;/3, pin ③ of 1C
outputs high level, K is powered on and closed, its normally open contacts Kl and KZ are connected, and the electric heater EH is energized and works for heating. The indicator light-emitting diodes
I and ED2 light up.
As the water temperature continues to rise, the resistance of RT also becomes smaller. When the water temperature exceeds the set water temperature value, the ② pin voltage of the IC will be higher than u, /
3. ③ The pin changes from high level to low level, causing K to be released, EH cuts off power and stops heating. LED 2 goes out.
The above process repeats itself, which can make the water temperature constant near the set water temperature value.
- DIY a practical audio-visual doorbell
- Disconnected anti-theft alarm circuit (1)
- Motorcycle anti-theft alarm circuit-a
- Electric massager circuit
- JS13 type transistor time relay circuit
- Commonly used oil pump motor control circuits for presses
- HTS fire alarm
- Electronic ventriloquist circuit
- Analog counter circuit circuit diagram
- Circuit diagram of Shenlong-Fukang DC7140 car diagram reading method example
- Set timing circuit when power is on
- Electronic thermometer circuit
- Agricultural small tractor lighting circuit
- AC voltmeter
- Diode Balanced Mixer Circuit
- Amplitude modulation circuit composed of MC1496
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Color display circuit
- Power phase sequence display circuit
- Small current generator circuit
