Digital linearization circuit that can set linear characteristics arbitrarily
Source: InternetPublisher:傻阿乐 Keywords: Linearization BSP ROM Updated: 2021/10/05
The analog signal of the linearizer is output in a unipolar range of 0 to +10v. Because
the input resistance of the A-D converter is very small, so adding an input buffer also
reduces the maximum conversion time of the two-bit A-port conversion. The clock frequency is 10pso powered by SZFci. .
The generation process of the clock is: converting the converted signal to nearly the same value tkA Jing-■
can achieve automatic operation, but a trigger pulse must be issued when the power is turned on, so,
use a. To differentiate the rising edge of the electric sweep, a trigger pulse is generated. ,.
The output data of the 8-bit DC converter is OOH ~ FFH, which is connected to the address line 4 of the EP- ROM
of the linear converter data . The address line of the EP- ROM 4t-F
can provide 15 types. Mode, select according to purpose and use. There is only
one mode that can select the same OOH-FFII data as the input signal, so the circuit adjustment will be very simple.
- Simple and practical EPROM detection circuit
- DIY Multimeter High Frequency Signal Probe
- Make a Economical and Practical Rectifier Voltmeter
- Homemade simple magnetic material tester
- How to Simplify Analog Front-End Design for Heart Rate Monitors
- Homemade LED digital display photovoltaic meter
- A simple electronic muscle stimulator circuit
- Application of TDA1514
- Light Detection 4 to 20mA Current Transmitter Circuit
- DC power meter
- High-efficiency speaker circuit for rural stage
- Fish pond oxygenation reminder circuit
- Agricultural small tractor lighting circuit
- Poultry warming temperature control circuit
- Farmland irrigation automatic control circuit a
- Diode Balanced Mixer Circuit
- Double detuned loop frequency discriminator circuit
- Diode square rate detection circuit
- Audio function generator composed of ICL8038
- Home appliance repair signal generator circuit
