R.sin conversion circuit that implements multiplication of analog input and digital data
Source: InternetPublisher:ghaytweyhtoo Keywords: Analog input conversion circuit ROM Updated: 2021/12/18
It is a circuit that multiplies analog input and digital data to perform R (data
/263) operation. The digital data value is O~2550. Prepare the ROM
data
corresponding to the sine function in advance . Because AD7s23 is a positive logic input, so
ainoo=O, port=ooH} sin900 =1, D=FFH (255/256≈l)o
Taking port 1 as a level, calculate sinoo~90 ports, then multiply by 265, and replace it with =
decimal point The following are rounded off) Save Qian P- ROM o
- Make a Simple Darkness Detector Circuit
- Detection of Bidirectional Trigger Diode
- Using NE555 to make diode and triode detector
- Circuit Fault Tracker
- A circuit for qualitatively testing capacitor leakage
- How to Simplify Analog Front-End Design for Heart Rate Monitors
- 4-range digital voltmeter circuit using ADD3701
- Homemade Metal Detector
- 1.5V and 9V battery tester circuit diagram
- AC equivalent amplifier circuit
- STMicroelectronics releases ROM-based GNSS module
- New fast charging I start 2 charging detection circuit
- Using window discriminator as intensity detection circuit
- Combustible gas concentration detection circuit
- Combustible gas detection circuit
- Detect the major point waveforms of the circuit
- Type A5349 AC Smoke Detection Circuit - Typical Application
- Multi-light sensor Brinell hardness detection circuit
- Thin object presence/absence detection circuit
- Combustible gas and toxic gas dual-purpose detection circuit
