DC field effect amplifier 01 using AP500A
Source: InternetPublisher:张三叔 Keywords: Power amplifier DC FET Updated: 2021/07/16
This amplifier is a two-channel amplifier. The core device uses the AP500A module. This device is a high-voltage high-speed dual J FET input amplifier
. It has an internal fine-tuning input offset voltage structure and
has automatic zero-adjustment (zero drift less than 90mV) during closed-loop operation. 30dB gain
, while having very small distortion (less than 0. oz%) and very
good voltage frequency response (OHz ~ 500kHz). With a few necessary peripheral
components, a wide frequency response DC power amplifier can be formed. As
shown in Figure 3-18 (only one channel is drawn) o In the picture, AP500A is used as
the voltage amplification stage, and VT1 and VT2 are used as the current amplification stage. The circuit is simple
. The front and rear amplifiers complement each other and are
indispensable The amplification stage uses the familiar VMOS field effect transistor, and its excellent musical characteristics as a
power amplifier
have been
recognized by most audiophiles.
- Lightweight and practical multi-core cable detection circuit
- Electromagnetic radiation monitor
- DIY Multimeter High Frequency Signal Probe
- Homemade Metal Detector
- Design of wireless meter reading system based on DSP
- NE555 makes a simple and practical acupoint detector
- Using NE555 to make diode and triode detector
- Making an Induction Electroscope Using CD4069
- Typical two-stage low-pass filter circuit
- High-speed gain programmable amplifier circuit
- Radio remote control doorbell circuit a
- Current output circuit of DAC0832
- DC servo isolation amplifier with low input frequency band from DC to 100kHz
- Motor drive circuit using PNP and NPN transistors
- Deli DCX-15 high temperature electronic tea set disinfection cabinet circuit diagram
- Using LM2579 to form +15V, -15V DC, DC converter circuit diagram
- Transformer coupled DC and DC converter circuit diagram using HS7076
- Stable output DC and DC converter circuit diagram composed of NE555
- High input voltage DC, DC converter circuit diagram
- 3V-12V DC DC conversion circuit 1
