Class A power amplifier power circuit
Source: InternetPublisher:走马观花 Keywords: power amplifier power circuit transistor Updated: 2021/10/07
The two (or two groups) transistors in the output stage of a Class A power amplifier (Class A power amplifier) are always in a conductive state, which means that they continue to conduct current regardless of whether there is a signal input , and make the two currents equal to the peak value of the alternating current. This When AC flows into the load under maximum signal conditions. When there is no signal, the two transistors each flow an equal amount of current, so there is no unbalanced current or voltage at the output center point, so no current is input to the speaker. When the signal tends to the positive pole, the output transistor at the top of the line allows more current to flow, while the output transistor at the bottom allows relatively less current. Because the current becomes unbalanced, it flows into the speaker and drives the speaker to produce sound.
- The basic principles of power supply design. What are the key components of a power supply?
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Schematic diagram of car cigarette lighter to USB power port
- The constant current source composed of two transistors can drive high power
- LED rechargeable flashlight circuit diagram
- Low cost and high performance LED constant current power supply
- Miniature polarity reversal power supply using MAX1721
- A simple positive and negative power supply circuit
- Adjustable voltage regulated power supply circuit
- Homemade home inverter circuit diagram
- Broadband multi-stage GaN-on-Si power amplifier module, do you know?
- TDA7241 power amplifier circuit diagram
- TDA7230A SD power amplifier circuit diagram
- TDA7057Q power amplifier circuit diagram
- TDA7052A power amplifier circuit diagram
- TDA2009 power amplifier circuit diagram
- TDA1518Q power amplifier circuit diagram
- TA7241AP power amplifier circuit diagram
- STK4372 power amplifier circuit diagram
- STK4362 power amplifier circuit diagram
