Broadband multi-stage GaN-on-Si power amplifier module, do you know?
Source: InternetPublisher:无人共我 Keywords: Power amplifier gallium nitride on silicon Updated: 2021/11/19
What is a broadband multi-stage GaN-on-Si power amplifier module? What does it do? February 14, 2019, Lowell, Massachusetts, USA – MACOM Technology Solutions Inc. (“MACOM”), a leading global semiconductor solutions provider ) announced the launch of the new MAMG-100227-010 broadband power amplifier (PA) module, expanding its gallium nitride on silicon (GaN-on-Si) power amplifier (PA) product portfolio.
This wideband PA module is optimized and improved for use in Land Mobile Radio Systems (LMR), wireless public safety communications, and military tactical communications and electronic countermeasures (ECM). The MAMG-100227-010 PA module combines the efficient design of a 50Ω fully matched, two-stage PA architecture with top- and bottom-side mounting configurability, providing radios with unprecedented design flexibility to achieve tight size, weight and power ( SWaP) specifications.
The new MAMG-100227-010 PA module utilizes MACOM's high-performance GaN-on-Si to achieve an extremely wide frequency band of 225 - 2600 MHz, 10W continuous wave output power, up to 40% typical power added efficiency (PAE), and 22dB typical power gain , and operating voltage up to 36V (typically 28V). The compact 14x18 mm air pocket laminate package with integrated gold-plated copper heatsink avoids PA architecture mismatches and therefore eliminates the need for additional components and PCB space. In addition, its top and bottom mounting configurability helps improve the installation flexibility and thermal agility of the PA module.
Mark Murphy, Senior Marketing Director of RF Power and Base Stations at MACOM, said: "MACOM has extensive experience in creating high-performance GaN-on-Si solutions for customers and providing field-proven and reliable performance. On this basis, MACOM has launched MAMG-100227-010 PA module... For customers who pursue excellent design flexibility, MAMG-100227-010 perfectly demonstrates MACOM's design and application expertise in various broadband frequencies and power levels, demonstrating MACOM's control."
For more than 60 years, MACOM's team of design and application experts has led innovative developments in the RF, microwave and millimeter wave fields and has developed the industry's richest portfolio of components covering the entire RF signal chain. MACOM's heterogeneous semiconductor and packaging strategies apply advanced proprietary technologies designed to ensure that every RF system function is fully optimized to deliver optimal performance and maintain cost advantages. MACOM always provides superior technology, expertise, cost structure and supply chain, striving for excellence without compromise, thereby providing customers with a real competitive advantage.
The MAMG-100227-010 power amplifier module is officially on sale today. To find MACOM optimized products that replace other vendors' products, see MACOM's cross-reference tool. The above is the analysis of the broadband multi-stage gallium nitride on silicon power amplifier module. I hope it can help you.
- How about the boost converter TPS61299?
- How to Make a Soft Latch Circuit
- Build a simple buck-boost regulator and test it on a breadboard
- Practical and convenient fax machine power supply control circuit
- Isolated two-wire current loop circuit (XTR101, ISO100)
- LM317 regulated power supply
- USB power socket using the car battery
- Constant current charger using light emitting diode as voltage regulator
- Mc34063 MP3 Switching Charger
- Adjustable voltage regulated power supply circuit
- TDA2822D power amplifier circuit diagram
- TDA2611A power amplifier circuit diagram
- TDA1555Q power amplifier circuit diagram
- TDA1551Q power amplifier circuit diagram
- TDA1516Q power amplifier circuit diagram
- TDA1020 power amplifier circuit diagram
- TDA1011 power amplifier circuit diagram
- TBA810S power amplifier circuit diagram
- TA7240AP power amplifier circuit diagram
- STK459 power amplifier circuit diagram
