Typical applications of TDA1085
Source: InternetPublisher:sigma Keywords: A10 BSP diode Updated: 2021/03/24
It generates AC bipolar signals, longitude. Received
pin 12. The positive half cycle of the speed measurement frequency causes the pump capacitor C to be charged on pin 11. Charging,
under the action of the internal F/V conversion circuit, the resistor R on pin 4. . The current flowing
is proportional to the motor speed. By R,. and ('. Adjust the characteristics of the F/V converter. There is a 470kn resistor in series between pin 11 and pin 9
, which helps to reduce the effect of temperature. The voltage
of pin 12 is monitored by the internal monitor. If the voltage is higher than 5v. The chip
stops working. For example, when the speed measuring generator is open circuit, the voltage at pin 12 will rise, causing
the trigger pulse to stop, preventing the motor from running out of control and overspeeding. There is a diode
in pin 12 of TDA1085C , which has a negative
direction for the negative half cycle of the speed measuring signal . Clamping function. There is no such clamping diode in TD A10 85A, so
a diode VD should be added to the direct circuit.
If a DC tachometer generator is used, it should be directly connected to pin 4 without using the internal
F/V converter. Just connect pin 12 to ground.
- A small improvement to the temperature and water level indicator alarm
- Simple phase failure protection circuit composed of intermediate relay
- Design and production of wireless multi-location control switch circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Design and production of no-load automatic power-off device for household power supply
- PIC microcontroller controlled remote anti-theft alarm circuit
- Homemade short circuit alarm device
- Water supply reminder after water outage
- Password type motorcycle anti-theft device
- Bicycle anti-theft alarm
- stuttering correction circuit
- Ultrasonic blind pathfinder circuit
- Homemade disinfectant circuit
- Greenhouse temperature control circuit
- Farmland drainage automatic control circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Thermostat control circuit using UAA1016B integrated circuit
- TDA1015T power amplifier circuit diagram
- TDA1013B power amplifier circuit diagram
- Threshold switching circuit using TCA105
