Integrated synchronous detector composed of analog multiplier MC1596
Source: InternetPublisher:常思一二 Keywords: Detector Analog Multiplier BSP Updated: 2021/11/19
The integrated synchronous detector composed of analog multiplier MC1596 is shown in the figure.
The demodulated signal can be any kind of amplitude modulation signal, input from the ① pin of the integrated circuit The demodulated original
modulated signal is output from pin ◎ and connected to an external low-pass filter. The required signal can be demodulated.
- The main characteristics, advantages and disadvantages of IoT protocols
- Methods to reduce mutual coupling between antenna elements
- What is the basic principle of parametric amplifier?
- TA8164P FM Radio
- FMA9901A FM broadcast dedicated antenna
- AM Transmitter
- Radio coding transmission circuit composed of MICRF102 and PT2262
- TR5100 FM 150~15 MHz transceiver
- RF2926 AM/FMASK/FSK/OOK 915/ 868/433 MHz Dual Conversion Transceiver
- rfPICl2C509AG/509AF ASK/FSK 480~310 MHz with 8-bit microcontroller transmitter
- Electronic thermometer circuit
- Ultrasonic blind pathfinder circuit
- Inpatient pager circuit
- Physiotherapy ventilator circuit
- Egg warming circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- ring amplitude modulation circuit
- Diode balanced amplitude modulation circuit
- Voltage series negative feedback amplifier circuit
- Guest arrival signal recognition circuit
