Use UC3634 to control single-phase brushless DC motor
Source: InternetPublisher:太白金星 Keywords: Brushless DC motor transistor Updated: 2021/07/24
UC3634 The circuit
structure and function of the motor phase-locked loop control
integrated circuit UC3634 are basically the same as UC3633, see Figure 4-14. The only difference is that in order to meet the needs of
single-phase dual-winding brushless DC motor applications, the 5-pin and 6-pin outputs are complementary
drives. The motor has a Hall position sensor, which is connected to pin 7 of UC3634.
In addition to getting a multiplied speed feedback signal and sending it to the phase detector like UC3633, it also
generates a commutation signal and outputs it from pins 5 and 6. Its driving capability is 20V, 30mA.
Using a piece of UC3634 and an external transistor , a complete single-phase four-pole brushless
DC motor phase-locked speed stabilizing circuit can be obtained, as shown in Figure 4-15. The motor speed is also 3600r/min.
- How to build a simple tachometer using an infrared reflectance sensor
- Tutorial for building a remote-controlled Arduino Air-Boat
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- A small improvement to the temperature and water level indicator alarm
- Motor automatic cycle control circuit
- Temperature control circuit design and analysis
- Audio interface protection circuit
- Infrared detection alarm
- Precious home appliance anti-theft alarm
- Rural fish farming control circuit
- Differential amplifier emitter negative feedback gain control circuit
- fire smoke control circuit
- Photocell trigger control circuit
- time control circuit
- Multi-pole leakage protector circuit a
- Automatic tuning control circuit
- Taifu DK2-25 rice cooker temperature detection control circuit
- Basic structure of power factor control circuit
- Wide input range non-synchronous voltage mode control circuit
