Taifu DK2-25 rice cooker temperature detection control circuit
Source: InternetPublisher:兰博 Keywords: Control circuit temperature detection rice cooker thyristor Updated: 2021/12/09
This is Taifu DK2-25 rice cooker temperature detection control circuit . The structure of this circuit is relatively simple. It uses a thyristor (thyristor
) to control the start-up of the rice cooker heater. AC 220 V voltage is applied to the rice cooker heater through the fuse FUI (185°C 5A) and thyristor
. The trigger terminal of the thyristor is connected to a switch contact controlled by a relay. The action of the relay will trigger the thyristor, causing the thyristor to conduct,
supply power to the heater, and start cooking. Since the rice cooker has a steaming and stewing function, it cannot completely rely on the temperature sensor at the bottom of the pot to determine whether the rice is cooked or not to
control whether to shut down. Moreover, when the water level drops to a certain level through the water level detection switch i, VT2 is turned on, and the relay K2 works, K2-I When turned on,
the alarm will activate. At the same time, due to the conduction of VT2, VTI is cut off, the relay Kl is cut off, the thyristor is cut off, the heating gas is cut off, and the cooking stops.
- What is a photocoupler and how to select and use one?
- Analysis of the flow direction of transistor current
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- What does a rectifier do? What is the process of rectification?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- Types and structures/characteristics/functions/implementations of smart sensors
- Ceramic filter structure/working principle/characteristics/application
- What types of force sensors are there?
- Touch circuit design and analysis
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Homemade disinfectant circuit
- Water dispenser double sheet control circuit
- Chandelier control circuit
- Multi-pole leakage protector circuit b
- Detection and control circuit of electromagnetic stove
- Microwave heating component control circuit schematic diagram
- Automatic sprinkler irrigation control circuit
- Electric heater temperature detection control circuit
- Temperature detection control circuit for vegetable greenhouses
- 35W half-wave resistor-capacitor phase-shift trigger actuation control circuit
