MC4044-MC4344 direct pulse width application circuit
Source: InternetPublisher:已注销 Keywords: Application circuit phase difference low-pass filter power amplifier Updated: 2021/08/17
VOUT can also be used to control switching power amplifiers and drive DC motors. It is suitable
for larger power control and has higher efficiency. There is a more simplified solution that only
uses U. of MC4044 phase comparator 1. The output directly controls the power switch. When U,
is L, the switch is turned on and the motor accelerates. After reaching the predetermined speed, U. Change to H,
turn off the switch and let the motor slow down. In steady state, V lags behind a certain phase difference to
maintain the motor operating at a predetermined speed. Due to the limited loop gain, this phase difference will be
relatively large. At this time, the motor works in the width modulation mode of the reference frequency fR.
The inertia of the electromechanical system acts as a low-pass filter . This direct pulse width modulation is applied as long as
the load changes are limited so that the duty cycle is within. . Within 15-0. 85, the system can work stably
. The schematic block diagram of this system is shown in the figure.
- How to choose the right level of integration to meet motor design requirements?
- Analysis of the working principle of car garage door lights
- Car ice warning circuit sharing
- DIY an electromagnetic levitation device
- What are the challenges in designing a permanent magnet linear generator?
- Perform surgery on the speaker protection circuit
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Design and analysis of the principle of automatic power-off switch during power outage
- Hydraulic control circuit design and analysis
- Combination circuit using shaping IC and filter
- Wiring to suppress microcomputer power grid interference with low-pass filter
- Commonly used low pass filter circuit d
- Commonly used low pass filter circuit c
- TDA7350 power amplifier circuit diagram
- TDA2611A power amplifier circuit diagram
- TDA2004 power amplifier circuit diagram
- TDA1518Q power amplifier circuit diagram
- TDA1013B power amplifier circuit diagram
- TDA1011 power amplifier circuit diagram
