Wiring to suppress microcomputer power grid interference with low-pass filter
Source: InternetPublisher:柯南道尔 Keywords: Low pass filter microcomputer wiring electromechanical Updated: 2021/04/21
Using a high-precision voltage regulator and correctly wiring it with the isolation transformer
and low-pass filter can further improve
the anti-interference ability of the power supply. The wiring is shown in Figure 20-48
and Figure 20-49. In the figure, the choke coil (Li,
Lz) uses
an MX0-2000 magnetic ring with an inner diameter of 18mm, an outer diameter of 24mm, and a thickness of 8mm as the magnetic core. Li
and L2 are each wound with 50 to 70 turns.
- How about the boost converter TPS61299?
- How to Make a Soft Latch Circuit
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- ISO113 circuit that can reduce power consumption
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Transformerless AC-DC constant current LED driver circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Converting a lithium battery charging board into a constant voltage and current charger
- Car Audio Power Supply
- Wiring of automated instruments against common mode interference
- Automated instruments use filters to resist interference wiring
- Isolation transformer and low pass filter wiring a
- Commonly used low pass filter circuit f
- Zinc oxide arrester wiring a
- audio low pass filter
- Uninterruptible power supply circuit for personal microcomputer
- Multiple feedback low-pass filter circuit
- Tunable fourth-order low-pass filter circuit diagram
