ML4411 typical application circuit
Source: InternetPublisher:念慈菴 Keywords: Application circuit BSP electric motor Updated: 2020/10/22
PWM and linear current control: In order to facilitate speed control, ML4411
is equipped with two current control loops, linear and PWM. The motor current is
detected by the voltage drop on the sampling resistor. It is input from pin 12. The built-in transconductance amplifier amplifies
the difference between pin 12 J (SENSE) and pin 28 (CMD>, and its output modulates three N
channels. MOSFET switch. This is a linear control loop. The (SENSE) signal is also compared with the 27
-pin J (LIMIT) signal in the comparator. The comparator output is connected to a monostable
circuit , and the latter is connected to the 13-pin external capacitor Cc )s timing. These circuits form the PWM
current limiting circuit. The function of these two circuits is to control the motor current to
the smaller of (CMD) and (I.IMIT).
(5) Braking control
In order to brake the motor, first make pin 8 zero level, and then make
the BRAKE level of pin 26 drop. When the level drops below 1.4V, the internal comparator forces the three
N-channel MOSFETs to turn on to brake the motor .
4Typical Application Figure 3-53 is an example of hard disk drive spindle control. Its
control signals come from the superior controller.
- Build a Smart Garage Door Opener Using a Raspberry Pi
- What is a RADAX motor?
- A small improvement to the temperature and water level indicator alarm
- Motor self-starting circuit
- Design and analysis of the principle of automatic power-off switch during power outage
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and analysis of a four-bit remote control component capable of remote reset
- An experimental model of an infrared radio alarm
- Infrared detection alarm
- Night dog barking anti-theft reminder circuit
- Set timing circuit when power is on
- electromagnetic field sensor
- Electronic anti-asthma circuit
- Varactor Diode Frequency Modulator
- Wien bridge oscillator circuit
- Capacitive feedback oscillator circuit
- Differential Amplifier Circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Color display circuit
- Sawtooth wave generator circuit (2)
