Build a Smart Garage Door Opener Using a Raspberry Pi
Source: InternetPublisher:兰博 Keywords: Internet of Things Smart Garage Updated: 2024/12/27
In this tutorial, we will build a smart garage door opener using Raspberry Pi. Here we will create a Raspberry Pi web server to open and close the garage door using your smartphone.
Required Components
Raspberry Pi board with Raspbian installed
Relay Module
Connect the wires
It is assumed that your Raspberry Pi has been flashed with an operating system and is able to connect to the Internet. If not, please follow the Raspberry Pi Getting Started tutorial before continuing. Here we use Rasbian Jessie to install the Raspberry Pi 3.
Here, an external monitor using an HDMI cable is used as a monitor connected with the Raspberry Pi. If you don't have a monitor, you can connect to the Raspberry Pi using a laptop or computer using an SSH client (Putty) or a VNC server. Learn more about setting up a Raspberry Pi headlessly here .
Circuit Schematic
Connect the garage door opener mechanism to the output of the relay. Here, for demonstration purpose, we have just connected an LED with the relay.
Flask setup for controlling garage door on Raspberry Pi
Here, we have created a web server using Flask, which provides a way to send commands from a web page to the Raspberry Pi to control the robot over the network. Flask allows us to run our python scripts through a web page, and we can send and receive data from the Raspberry Pi to the web browser and vice versa. Flask is a microframework for Python. This tool is based on Unicode and has a built-in development server and debugger, integrated unit testing support, support for secure cookies, and its ease of use, which makes it useful for hobbyists.
Run the following command to install Flask in your Raspberry Pi:
sudo apt-get update
sudo apt-get install python-pip python-flask
Now, run the pip command to install Flask and its dependencies:
sudo pip install flask
You can learn more about programming with Flask here , and you can also check out our previous projects where we used Flask to control a robot through a webserver, send messages from a webpage to a Raspberry Pi, and send weight values to a Raspberry Pi in a Smart Controller.
Now, we will write a Python script for our garage door web server.
Creating a Python Script for a Smart Garage Door Opener
This script will interact with our Raspberry Pi GPIO and set up the web server. So, this is the core script of our application. Finally, given is the complete door opener Python script, here we explain its several parts.
First, make a folder. All other required folders should be in this folder only. Run the following command to create a folder and create a python file named app.py inside this folder.
mkdirgarage_do
This will open the Nano editor where we have to write our script.
First include the important libraries.
from flask import RPi.GPIO as GPIO Import Flask, render_
Now, create a dictionary as pins to store the pin number, name, and pin status. You can use as many pins as you want.
pin = { 14 : {'name' : 'Garage door', 'state' : GPIO.LOW} }
Then, set the pin to output and initially set it low.
For a pin in a pin: GPIO.setup(pin, GPIO.OUT) GPIO.OUTPUT(pin, GPIO.LOW)
Now, create a main function to read the pin status and store this status in a variable.
@app.route("/") def main(): for pin in pin: pins[pin]['state'] = GPIO.input(pin) ..
We have to pass this data to our html page so that we can control the state of the input button.
return render_template('main.html', **templateData)
Now, create a function to handle the request from the URL, which contains the pin number and action.
@app.route("//", methods=['GET', 'POST']) def
Converts a pin from a URL to an integer.
changePin = int(changePin)
If the action portion of the URL is "Open", the following actions are performed.
if action == "open": GPIO.output(changePin, GPIO.HIGH) if action == "close": GPIO.output(changePin, GPIO.LOW)
You can copy the complete script from the end of this tutorial and save it using ctrl+x and then press enter. We have completed the python script. Now, we have to make an HTML page to interact with the python script.
Creating HTML Pages for the Raspberry Pi Webserver
In the same garage_door folder, create another folder named templates and in that folder create a .html file using the following command.
In the nano text editor, write html code. You can edit the page
section and style it according to your choice. I have just used a third party css solution using link tag. The complete HTML code is as follows:
The important part here is to create a button to open and close the door and assign a state to the open and close button. This button will send and get the GPIO state from the python script.
You can use the above given HTML code in your editor and save it. Now the web server is ready to start.
Open terminal and navigate to garage_door folder and run the following command
sudo python app.py
Open your browser and type in your Raspberry Pi IP address and press enter. To find your IP address, you can run the following command in the terminal.
Hostname-I
You will see a page like this.
Make sure the relay module is connected to the Raspberry Pi. Press the On button to turn on the relay or open the garage door. You can also view the status of the relay. Once you turn on the relay, the button text will change to Off to turn off the relay. Now, when you click the button again, the relay will turn off and the button text will change to On again.
To stop the server, press ctrl+c.
So, just connect this relay to some door opener mechanism readily available in the market and start controlling your garage door using your smartphone. from flask import RPi.GPIO
import Flask
as GPIO , render_template, request
app = Flask(__name__, static_url_path='/static')
GPIO.setmode(GPIO.BCM)
pins = {
14 : { 'name' : 'Garage Door', 'state' : GPIO.LOW}
for pin in pins:
GPIO.output(pin, GPIO.LOW)
@app.route("/")
def main():
for pin in pins:
templateData = {
'pins' : pins
return render_template('main. html', **templateData)
def action(changePin, action):
deviceName = pin[changePin]['name']
for pin in pins :
pin[pin]['state'] = GPIO.input(pin)
templateData = {
"pin": pin
if __name__ == "__main__":
app.run(host='0.0.0.0', port=80, debug=True)
GPIO.cleanup()
- How to choose the right level of integration to meet motor design requirements?
- An automated model railroad layout project using a microcontroller
- Motor self-starting circuit
- Motor control circuit for starting and running without phase loss
- Using P110C to control 6 DC motors simultaneously
- Design and analysis of a four-bit remote control component capable of remote reset
- Design and production of no-load automatic power-off device for household power supply
- Password type motorcycle anti-theft device
- Vibration anti-theft alarm circuit
- "Watchdog" anti-theft alarm circuit
- Homemade disinfectant circuit
- Electric plow control circuit
- Photocell amplification control circuit
- Ringtone control circuit
- Boiler control circuit
- AM radio automatic search and trigger circuit
- High-rise residential walkway lighting control circuit
- 24h automatic switching capacitor control circuit
- Steam iron temperature detection control circuit
- Taifu DK2-25 rice cooker temperature detection control circuit
