Motor drive circuit using two N-channel FRTs
Source: InternetPublisher:子丑寅卯 Keywords: Motor drive circuit FET Updated: 2020/09/26
For LS7261/LS7262, connect pin 5 to the aluminum positive pole of the power supply, and all six
output FETs of the circuit will become source outputs. Figure 3-1a~ Figure 3-12 show different level transfer
circuits to adapt to different power switch combinations. Figure 3-10 applies to PNP and
NPN transistor combination circuits, and only one bridge arm is shown here. It uses V. For
level transfer, when the output of pin 2 is high level, V. Conducted, through the support to V. The tube provides
base drive current, making v. conduction. If pin 2 is low level, v. The tube is cut off, and
V is caused by the action of R. Quick cutoff. V: The tube is connected with a follower, and V is controlled by pin 6. On or
off. If the motor uses a higher voltage, R. and R, the power consumption will be very large. At this time,
it is necessary to connect the acceleration capacitor on R, and the protection diode on the e and b poles of V. The high power dissipation
of the resistor is the disadvantage of this circuit. Figure 3-11 uses P-channel and N-channel
FETs. This problem is solved. However, the on-state resistance of P-channel FET is larger than that of N-channel
FET . The higher on-state resistance reduces the switching speed, increases losses,
reduces efficiency, and reduces reliability.
- Servo motor pin diagram/working principle/application
- How to remotely control devices using ESP8266 and LPC2148
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- What is a RADAX motor?
- DC motor drive circuit composed of L293D
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Car audio system anti-theft circuit
- Vibration anti-theft alarm circuit
- "Watchdog" anti-theft alarm circuit
- Homemade disinfectant circuit
- Infrared voice control circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- Chandelier control circuit
- sound control circuit
- Schematic diagram of motor PLC control circuit
- Multi-pole leakage protector circuit a
- MOS-FET switch pulse output circuit diagram
- AD824 single supply positive and negative supply limited output low power FET input operational amplifier
- Oscillator circuit diagram using FETs and transistors
