Star-delta step-down starting control circuit for squirrel cage asynchronous motor
Source: InternetPublisher:兰博 Keywords: Asynchronous motors Updated: 2024/11/13
For squirrel cage asynchronous motors above 10kW, their large starting current (5 to 7 times the rated current) will have a huge impact on the power supply system, so they are generally not started directly at full voltage, and are usually started by reduced voltage. Since squirrel cage asynchronous motors above 4kW are all connected in a triangle during normal operation, the use of star-triangle reduced voltage starting can effectively limit the starting current. The star-triangle reduced voltage starting control circuit is shown in the figure below.
When starting, the motor stator winding is connected in star shape, so that the voltage applied to each phase of the motor winding is the rated value, and the current is only 1/3 of the rated value, thereby significantly reducing the starting current. When the motor speed gradually increases and approaches the rated value, the stator winding is switched to a triangle connection and switched to normal operation at the rated voltage.
In order to realize the automatic switching of the starting process, a time relay KT is used in the control circuit. After pressing the start button SB2, the contactor KM is energized and self-locked, KMY is also energized, and the motor starts to run in star connection. At the same time, the coil of the time relay KT is also energized and starts timing. When the set time is reached, its contacts act, the delayed disconnection contact of KT disconnects KMY, and the delayed closing contact connects KM△ and self-locks, so that the stator winding of the motor switches to the triangle connection and turns to normal operation under the rated voltage.
- DIY a simple fire alarm
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- An automated model railroad layout project using a microcontroller
- Introduction to the internal structure of the Delta winding motor
- Motor control circuit for starting and running without phase loss
- One-way rotation circuit of motor controlled by contactor
- Design and principle analysis of practical electric curtain remote control device
- Magnetic door and window anti-theft alarm
- Precious home appliance anti-theft alarm
- Homemade anti-theft watchdog
- Multi-channel patrol detection control circuit c
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Chicken farm photoelectric control circuit
- Car window control circuit
- Three-phase stepper motor control circuit
- Chandelier control circuit
- Typical operation display circuit
- Automatic sprinkler irrigation control circuit
- Control circuit of Gao Shida 25860T microwave oven turntable assembly
- audio signal control circuit
