The production of "Walkman" power connector 03
Source: InternetPublisher:qoistoochee128 Keywords: controller integrated circuit toshiba Updated: 2021/11/14
If the player itself does not have a tone function, the high-fidelity DC control tone controller shown in Figure 5.90 can be used . The integrated circuit
used in this circuit adopts the special tone volume control integrated circuit TDA7630 from Toshiba Corporation of Japan . This circuit uses
ordinary single potentiometers to achieve dual-channel control. 6 This circuit can be designed in the balanced position. RP1. RP2 and RP3 are used to adjust volume, treble, and bass
respectively This circuit is very good at adjusting treble and bass. , the bass is not muddy,
and there is also a negative feedback tone controller that makes the treble sound harsh when it reaches its peak. This circuit is still designed to be powered by dual power supplies. The power supply is introduced from the power amplifier to the three
-terminal voltage regulator CW 7806/ CW 7906. After stabilization, it supplies power to the TDA7630. During production, please note that the heat dissipation
terminal of 7806/7906 should not be short-circuited. This is because the heat dissipation terminal of 7806 is connected to ground; and the heat dissipation terminal of 7906 is connected to the negative power supply.
- Simple electric tachometer
- Analysis of valid and fault conditions of differential signals
- Leakage Tester
- Homemade LED digital display photovoltaic meter
- A low-cost inductance meter consisting of a single IC
- An electronic load meter using LM324 operational amplifier as the main control device
- Use LM3915 to make a practical audio power meter
- Test of leakage current of switching appliances
- DT8 type 5A current mutual induction three-phase four-wire active energy meter wiring
- Phase sequence indicator circuit diagram
- Microchip maXTouch® touch screen controller, did you know?
- Electroplating driving PLC control ladder diagram
- Toshiba ultra-thin DVD player switching voltage stabilizing circuit
- Multiple cam controller circuit
- STK-W-3 microcomputer controller peripheral circuit
- Use CD4069 and CD4017 to make a novel light flashing controller
- Wire-controlled music lights and stepless dimming dual-purpose controller
- CJM03 composed of fuse scrap emergency controller
- Charging circuit diagram using LM3914 as controller
- Multi-variable flow light controller
