High quality stereo HI-FI combo amplifier 02
Source: InternetPublisher:失踪的猫 Keywords: Amplifier Stereo HI-FI Controller Updated: 2020/03/11
(2) The central component of the ten-fold circuit amplifier and tone controller
still uses the king of op amps NE5532.
When 1C1 is used as a ten-fold circuit amplifier , it is to compensate for
the lack of gain when the tone controller is used alone. IC2 forms a negative feedback
tone controller, and RP1, RP2, and RP3 are used for low, mid, and treble adjustments respectively. The control range is not less than ±12d8. RP4
is the volume controller. This tone controller uses the operational amplifier NE5532. The control effect on low and treble is excellent, the treble is clear
and delicate, and the bass is rich and powerful. Especially the bass control effect is excellent, surpassing some so-called bass add-on boards. Interested parties may
wish to compare this tone controller with commercially available multi-band tone equalizers to see which one is more cost-effective. Considering the independent use of this
tone controller , the power supply of the op amp NE5532 is stabilized by voltage stabilizing blocks 7815 and 7915, so there is no need to use this voltage stabilizing
block.
- 4040 Mobile Phone Electromagnetic Radiation Demonstration Experiment Circuit
- A highly sensitive human proximity detector
- Simple electric tachometer
- TC02 temperature measurement circuit
- LM3914 makes car battery detector
- How to Use a Radio as a Metal Detector
- Four logic probe circuit diagrams
- Test of leakage current of switching appliances
- direct coupled amplifier circuit
- Directly coupled push-pull power amplifier circuit
- TI TCAN4550 system basic chip analysis
- A typical application circuit diagram of PS61040
- Conveyor belt control ladder diagram
- variable gain amplifier
- 26kW AC three-speed cargo crane control circuit
- Control and protection circuit composed of master switch and cam controller
- Fever Sanbanax HI-FI
- Homemade active two-way HI-FI amplifier 02
- Installation and debugging of Powon-HE328 Hi-Fi power amplifier
- HI-FI integrated amplifier TDA7294-02
