Power amplifier LM1875 and applications 01
Source: InternetPublisher:sigma Keywords: Power amplifier LM1875 BSP power amplifier circuit Updated: 2021/05/02
IJM18 75 is a product review of National Semiconductor Corporation (NSC). This device is a widely used final power amplifier
, suitable for power amplification situations in audio amplification, servo amplification, bridge amplification, and test systems. It has few peripheral components,
high power without distortion, and can work with both single and double power supplies. And the circuit has its own safe working area protection circuit (inductive load) for overload, overheating and reverse potential suppression
, which is an ideal application circuit port for high- and mid-range audio.
This device has the following characteristics:
(1) Single and double power supply, wide range Voltage range (single lzv ~ 50v or dual ±6V ~ ±50v);
(2) Maximum undistorted power is 30W;
(3) Low distortion output (less than 1% at 30W);
(4) Open loop gain 90dB;
( .5) The quiescent current is less than 100mA;
(6) The maximum output current is 4A;
(7) The maximum swing rate is 8V/Ps. The appearance and pins of
LM1875 are shown in Figure 5-22. The OCL power amplifier circuit principle is shown in Figure 5-23; the OTL power amplifier circuit principle
is shown in Figure 5-24; BTI. The power amplifier circuit principle is shown in Figure 5-25.
- Simple and practical EPROM detection circuit
- System display circuit of electric bicycle speed and odometer composed of CD4076 and 74LS138
- Analysis of valid and fault conditions of differential signals
- TC02 temperature measurement circuit
- Temperature-frequency conversion circuit composed of CD4046
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- Digitally controlled operational amplifier gain circuit
- DC power meter
- DS8 type 100V, 5A mutual inductance three-phase three-wire electric meter wiring
- Phase sequence indicator circuit diagram
- Peanut and melon seeds roasting machine circuit
- Agricultural small tractor lighting circuit
- Straw returning to field crusher circuit
- Farmland drainage automatic control circuit
- Amplitude modulation circuit composed of MC1496
- ring amplitude modulation circuit
- Audio function generator composed of ICL8038
- Voltage series negative feedback amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- superheterodyne radio circuit
