Assembling a BTL Hi-Fi Amplifier with LM1875
Source: InternetPublisher:蓝猫淘气 Keywords: hi-fi amplifier LM1875 BSP Updated: 2020/01/18
The pre-stage uses a high-quality 10x amplifier with the core of the op amp NE5532 to match the input sensitivity of the LM1875
The preamplifier power supply is best to use a high-speed active servo circuit. High-quality IC must be equipped with high-quality peripheral components, such as
CBB capacitors or tantalum electrolytic capacitors for coupling capacitors; ELNA capacitors for feedback capacitors; and 2×lOOOOr.JLF "black gold" for filter capacitors.
"Just" (each channel) connect 0.22tj:F CBB capacitor in parallel; the resistor uses five-color ring metal film resistor, etc.
It is best for the transformer to adopt "Huan Niu" with secondary AC voltage of 2X18V.
When the whole machine is installed and debugged, if the circuit has self-excitation, the capacitor value in the phase-shifting network circuit should be carefully adjusted. Generally, the static
voltage should be 0mA ~ 80mA. If the requirements are not too high, the phase-shifting network can also be cancelled. The circuit of one channel is shown in Figure 5-19, and
the circuit of the other channel is exactly the same.
- Convenient and fast power line break detection circuit
- New function added to MF-47D multimeter - infrared remote control detection
- Homemade Metal Detector
- Using NE555 to make diode and triode detector
- How to Simplify Analog Front-End Design for Heart Rate Monitors
- Leakage Tester
- 5 tone detector circuit diagram
- How to use STM32 to design an alcohol tester
- DC power meter
- electromagnetic field sensor
- Analysis of rectifier circuit types and principles
- Homemade disinfectant circuit
- Agricultural temperature control circuit
- Chicken supplementary light to increase egg production rate circuit
- Agricultural spraying and insecticide control circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage controlled power supply second-order high-pass filter circuit
- Various signal generator circuits
- Sawtooth wave generator circuit (1)
