Two tube OTL amplifiers 02
Source: InternetPublisher:吃掉星星 Keywords: Amplifier tube BSP output transformer Updated: 2020/07/04
It is a well-known fact that the performance of the insulator is closely related to the quality of the output transformer . Overseas equipment
products also include so-called tube OTI-amplifiers that simply eliminate the output transformer . The amplifiers
shown in Figure 1-31 and Figure 1-32 are two of these products. Both tubes are domestic products, and the circuits are basically
the same. The difference is the model of the power tube, Figure 1.31 uses 6P13P; Figure 1-32 uses 6C19, and
6N1 is used for the inverter and voltage amplification parts. 9 As commercial equipment, the most important thing is to introduce new things, so replace them like this The practice of setting up a separate model of power tube
can be used as a reference for audio enthusiasts
- What are the classifications of filters?
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Diode-based clipping circuit
- How does RCCB work?
- Simple LED advertising light circuit
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- An example of proportional integral circuit diagram
- Circuit diagram of a differential amplifier circuit
- Homemade air conditioner outdoor unit shutdown indicator
- electromagnetic field sensor
- Physiotherapy ventilator circuit
- Biogas concentration detection line
- AC voltmeter
- Integrated synchronous detector composed of analog multiplier MC1596
- Diode square rate detection circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Guest arrival signal recognition circuit
- Power phase sequence display circuit
- Sawtooth wave generator circuit (1)
