Practical high-power switching regulated power supply circuit schematic diagram
Source: InternetPublisher:已注销 Keywords: High power circuit schematic diagram regulated power supply circuit switching regulated power supply Updated: 2021/11/04
The figure shows the schematic diagram of a practical high-power switching regulated power supply circuit . The mains power is stepped down by power transformer TR1, rectified by diodes VD1~VD4, and filtered by capacitors C1 and C2 to obtain a DC voltage of nearly 40 V. Pins 1 and 2 of the switching regulator integrated circuit IC are DC voltage input terminals, and its maximum input voltage is +40 V. This DC voltage is modulated by the oscillator inside the IC into a high-frequency switching voltage of about ⒛0kHz. The switching frequency of the oscillator is determined by the external oscillation capacitor C4. When the value of C is 3300 pF, the switching frequency of the power supply is about 25kHz; resistor R3 and capacitor C6 form a loop adjustment amplifier frequency compensation network, which is input by pin 7 of the IC. Pin 4 of the IC is the suppression input terminal, and the threshold of the blocking voltage is 0.7 V. The output voltage is fed back to pin 4 through the sampling resistor R2 and then compared with R1. When the threshold voltage is greater than 0.7 V, the output is turned off. Short circuit overcurrent protection. Pin 6 is the output voltage adjustment control terminal. The output voltage is divided by the potentiometer RP and the resistor R4 to obtain the adjusted voltage detection value. Adjusting the potentiometer RP can control the output voltage. Pin 8 is the output terminal. In addition, VT is the current amplifier tube, VD5 is the reverse freewheeling diode, and L is the filter inductor.
- How to Make a Soft Latch Circuit
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- How to use SBR to improve power conversion efficiency
- LNK304 non-isolated LED light string driver circuit
- A small and easy-to-make fast charger
- An ultra-low output voltage regulator
- Converting a lithium battery charging board into a constant voltage and current charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Adjustable voltage regulated power supply circuit
- Circuit diagram explanation: simple switching power supply circuit diagram
- DC-RRS application circuit a
- 22V, 100A high-power regulated power supply circuit
- Novel high-power multi-functional amplifier module 01
- High current switching regulated power supply application circuit
- Principle of high current switching regulated power supply circuit
- Integrated switching regulated power supply circuit 02
- High power non-contact street light automatic control circuit
- Simple high-power temperature control circuit
- Overcurrent protection circuit diagram of high-power DC motor
- High power festival flowing water light chain
