An ultra-low output voltage regulator
Source: InternetPublisher:司马缸砸光 Keywords: Voltage Regulator Updated: 2024/08/15
The transistor 2N797 used as a diode is a germanium tube, while the 2N2222 is a silicon tube. Its reference voltage is generated by the bandgap voltage difference between the two tubes, and its value is about 0.5V. LM111 is not an ordinary operational amplifier, but a voltage comparator specially designed for very low input current. When powered by a 5V power supply, its minimum output voltage can be adjusted to 0V. The circuit with the structure shown in the figure can adjust the minimum output voltage to nearly 500mV. The temperature coefficient of the entire voltage stabilization circuit is also very low.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Step-down power supply for driving relays
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Boost drive circuit composed of RT8450
- CNC regulated power supply production
- Electric bicycle battery charger circuit
- MIC4680 constant current charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- MAX1811 Lithium Battery Charger Production
- Homemade Electric Bike Fast Charger
- Importance of Voltage Supervisors and Output Topology Selection
- 24V power supply pure flat display high voltage power supply circuit diagram
- Solar power circuit
- 3v to 5v circuit diagram
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- Single phase thyristor slotless nickel plated power circuit
- audio power circuit
- Common power circuits and applications 09
- 25Hz ring current power supply circuit
- High Efficiency Negative Voltage Regulator Circuit
