LMD18400 for four-phase stepper motor drive
Source: InternetPublisher:MartinFowler Keywords: stepper motor short circuit MOS Updated: 2020/12/16
The ON state resistance of the D MOS power switch has a positive temperature coefficient, and the four switches can be
connected in parallel to increase the load current. Therefore, a single LMD18400 can drive one,
two, or four small DC motors. Inputting the PWM control signal from the input terminal can realize
the speed regulation control of the motor, see Figure 11-12 and Figure 11-13.
The LM 1951 is a high-speed (up to 50kHz) high-side smart switch. It can provide the following fault
protection and have fault indication output: output terminal short circuit to ground or positive power supply ,
negative open circuit, over-current, over-voltage, over-temperature. It is suitable for driving resistive and inductive loads.
The output has a 30V clamp to quickly discharge inductive loads. The input control terminal is TTL/
(' MOS compatible and has ESD (anti-static) protection.
- Analysis of the working principle of car garage door lights
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- How can we make the robot move precisely on a predefined path?
- How to set up a cheap beam break sensor control distance scene using a reflector
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- One-way rotation circuit of motor controlled by contactor
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Infrared blocking alarm device
- Differential amplifier emitter negative feedback gain control circuit
- Electromagnet control circuit
- Three-phase stepper motor control circuit
- Haier KFR-25GW air conditioner control circuit schematic diagram
- Fully symmetrical MOS FET 100W hi-fi amplifier 01
- AC to DC converter
- LMD18400 for four-phase stepper motor drive
- Electronic analog switching circuits driven by TTL or MOS circuits
- Circuit diagram of double voltage circuit with C-MOS inverter attached
- ECL to VMOS interface circuit
