H-bridge drive circuit composed of Smart SIPMOS
Source: InternetPublisher:难得正经 Keywords: MOS SIP driver circuit Updated: 2021/04/26
Using two BTS412B as high-side switches and two BU271L power MOSFETs
(50v, 䉉1n) as low-side switches, an H-bridge bidirectional DC motor drive circuit can be formed ,
as shown in Figure 11-1l. This circuit is designed for an electrical automatic door with a continuous current of 6A.
The four-leg switch is directly controlled by C MOS logic levels. The two BTS412B status outputs
are driven by a transistor with OR logic and an LED indicates the fault status. The middle point of the left bridge arm
is connected to a 12ktl resistor to the ground so that when all four switches of the H-bridge are turned off, the BTS412B will not
mistake it for an open load. Once a load open circuit occurs, the BTS412B on the right can detect
it and send a fault signal.
- A simple door handle touch alarm circuit
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- How to set up a cheap beam break sensor control distance scene using a reflector
- Working principle of one Xipu STR soft starter controlling two motors
- Motor automatic cycle control circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Simple phase failure protection circuit composed of intermediate relay
- An experimental model of an infrared radio alarm
- Password type motorcycle anti-theft device
- "Watchdog" anti-theft alarm circuit
- Homemade disinfectant circuit
- Rural fish farming control circuit
- Boiler control circuit
- AM radio automatic search and trigger circuit
- High-rise residential walkway lighting control circuit
- Chandelier control circuit
- SIPMOS transistor complementary Darlington control circuit
- Circuit diagram of a half voltage divider circuit with an additional C-MOS inverter
- Circuit diagram of using SG3525A double-ended output to drive MOS power tube
