Working principle of one Xipu STR soft starter controlling two motors
Source: InternetPublisher:兰博 Keywords: Starter Motor Updated: 2024/11/13
Using one STR soft starter to control two motors does not mean starting them at the same time. Instead, one motor is started and the other is kept as a standby. The circuit is shown in the figure below.
How it works
If a soft starter is used to control a motor, the motor M2 in the figure below can be cancelled. The secondary control circuit composed of KM1, KM2, etc. is shown in the wiring diagram of a soft starter controlling a motor.
The figure below shows a wiring diagram of a soft starter controlling two motors. This circuit is connected to a part of the control circuit outside the soft starter, and the motor is selected for use and standby through the conversion switch SA. SA is turned to "2" to select motor M1 as standby. When QF is connected at the current position as shown in the figure below, the AC contactor KM1 coil is energized and attracted, and its main contact KM1-3 is closed to prepare for starting motor M1. The indicator light HI. l lights up, and then press the RUN key on the STR operating keyboard to start the motor: press the STOP key to stop the motor. The JOG button is set by the user according to the needs. The operating keyboard does not have this function and needs to be installed separately.
- A simple magnetic switch circuit sharing
- DIY an electromagnetic levitation device
- How can we make the robot move precisely on a predefined path?
- A small improvement on the ordinary refrigerator motor starting circuit
- Working principle of one Xipu STR soft starter controlling two motors
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Methods for Eliminating Noise of Brushed DC Motors
- Add one more component to improve the phase failure protection function
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- PIC microcontroller controlled remote anti-theft alarm circuit
- 13 examples of electric drag control circuit diagram
- Boiler control circuit
- Microwave oven control circuit
- Multi-pole leakage protector circuit a
- Haier KFR-25GW air conditioner control circuit schematic diagram
- Digital current loop control circuit
- Typical operation display circuit
- Timing and fire power control circuit
- Photoelectric detection output control circuit
- XJ10 series auto-coupling step-down starter starting circuit
